So I am in the process of building out an invoice approval workflow and realized the way I am doing it will require hundreds of steps. Is there any easier way to do this? Here is the scenario.
I create a library where finance uploads the invoice and tags the department and amount.
25 Different Departments, different approvers for each, and multiple approvers based on the invoice amount.
Example: IT Department. If under 5k User1 approves, if over 10 K User1 and User2 must approve, if over 50k User1, User2, and User3 must approve. And the approvals must go in order. For a 50k approval User1 must approve before User 2 gets a task and so on.
I created an invoice escalation list to hold these values and the workflow references that as it moves along. Checks the department then starts the task for user1, then moves along with lots of if statements.
I attached a picture of how I am doing this. Is there someway to put all the if statements in one stage or some kind of variable I can do to make this easier?
I am attaching a picture of the list which holds the approvers and escalation amounts. I think that will clarify what I am trying to get this workflow to do without 3 days of typing.
There is always the first task going to the department’s approver but after that additional tasks are only required if the invoice amount is over.
Are the approver amounts all static? I believe you could use only 3 total Start a Task Process actions and use workflow lookups in each to populate the assigned to by variables and your invoice escalation list. When configuring a Start a Task Process you can declare that the assigned to users can run in serial {one at a time). These are supposed to go in the order in which you have them entered in the field. So for the 10k approval you can lookup to the escalation list for both assigned to fields where department = something and approval rate = xx.
