Dears,
I have SharePoint 2013 SharePoint Farm with SQL 2012 as back end database. I have configured the SSRS on the farm. The Reports are displayed perfectly in browser but when i try to open the report in Report builder, I get the error: “The remote server returned an error (403) Forbidden”.
Nothing is recorded in event viewer or ULS logs for this.
Any ideas how can I overcome this error?
hi  Ionut,
I use windows credentials to connect to data source. Please see the attachment. The connection type is set to SQL Server.
What kind of authentication do you use in your data source? Â Check the log of SQL Server, you might see a login failed when you do this. I suppose the same will happen if you try to display a similar report in Excel.
