Im running Sharepoint 2013 as a standalone and im unable to figure out how to add users.
Do these users need to have accounts on the server in order to be added to sharepoint? Or is there someway other way to create users in sharepoint?
Is this server is Connected to Your Domain or is it your Home Server.
If its connected to Domain you can choose the user straight away by typing their name you don’t need to add users on the server.
If you used the stand alone without domain connection then you need to add the users on that server to use in the sites.
Note:
User Profile Service will not be avaliable on Standalone installations.
Not Sure what authentication it used, i installed it as a standalone on a server for testing and it just created an account from and for the administrator on the server that i used to install it.
I’m not sure what claims is, sorry really new to this, when installing i was hoping it would let me create an admin but it just did it on its own.Â
Been trying to find some documentation but few things help with standalone installment. And finding it by going through like 20 different links between microsoft pages doesnt really help.
Hi, you need some sort of authentication provider such as AD. What authentication method have you used on your Web Application? If created through the GUI it will be claims (which claims provider did you choose) by default and unless you specified and did it in Powershell to create your Web Apl it will more than likely be windows classic.
