I’m in the process of setting up Web Analytics on my vm. I have the Web Analytics Service Application provisioned/started (as well as Usage and Health). The services (Analytics Web Service and Analytics Data Processing Service) are both started. ULS and Usage files are being created as expected and the Data Import timer job is running every 30 minutes as expected.
I’ve been running the Data Processing timer job manually in an attempt to process the import data, but it doesn’t show any results. Reviewing the [WASetting] table in the Reporting database still shows 19000101 as last processing dates. I’ve tried running Verbose logging for Analytics, but I’m not seeing any errors come up in the ULS logs (or in the Eventviewer).
Is there anything I’m missing that might affect the processing service?
Darren
SP2010 SP2 w Feb2013 CUM, Windows 2008 R2
