Can anybody help??
I am working on a SP 2010 site and have managed to create a ‘blog navigator’ on the left hand side of a category on a blog site. This is also duplicated on the right hand side of the screen as a web part which i need to keep but when I try and delete the web part, it removes the other one also.
I have no idea what a blog navigator is and don’t know how I’ve got it there.
Any help would be really appreciated.
Thank you.
Louise
Thank you for your response. After much deliberation, I have come to the conclusion that blog sites are not going to work for this particular project any way so have turned to a team site instead. Thanks again, Louise.
Would hiding the Quick Launch work for you? You can put the following into a text file, and then put a hidden Content Editor Web Part on the page, pointed to that text file, to hide the quick launch.
<style type=”text/css”>
.v4master #s4-leftpanel
display: none
.v4master .s4-ca
margin-left: 0px
</style>
