Hello all,
My company is planning in migrating from sharepoint 2007 to sharepoint 2013. Can anyone please provide me the major differences happening after migrating to sharepoint 2013.
I know we dont have design view in sharepoint 2013
Hotspots are not allowed in 2013
What are the changes are there when compared to 2007 into 2013 with regards to workflows and infopath.
We have a lot of workflows and infopath in sharepoint 2007. Not sure how this will effect in sharepoint 2013
Your helpful will be much appreciated.
Thanks a lot
Thanks Robin for the response. This is what I was also facing problem into. Hence trying different migrations tools to see if any of them help migrating workflows and infopath. Do you have any solution or any migration tools who can help us in migrating workflows and infopath?
Can you also provide me the how the new templates were created.
The workflows and forms will not migrate well. We able to migrate the forms libraries we had. (in other words existing content (forms) migrated and is viewable in some instances. Workflow did not migrate at all). We did not expect the SPD2007 workflows to work in 2013.
we ended up creating new templates/libraries for all of the forms and writing new workflows.
Thanks peter for the info. Will check into it. Did you migrate workflows and Infopath from 2007 to 2013
Did you migrate workflows and Infopath from 2007 to 2013 using sharegate. Since when I try doing the trial version of sharegate and tried to migrate the workflow and infopath its seems it didnot work for me. Not sure if that work if we buy the tool. Let me know what kinds of contents did you migrate.
Mohammed, we used ShareGate to migrate our content and that seemed to work well.
