Can I re-use a Form or Quiz (with a different class)? Do I need to clear previous results?
Hi, if you make a copy of your Form everything will be copied except the results. It will become a new instance. Please make sure you check the settings to see if it is not expired or closed, because that will be copied, too! Â
