I did use the template for creating a csv file with Flow and that worked, but by the time I was able to use a Select action to pull only certain columns from the SharePoint list, that same trick didn’t work anymore.
Any ideas?
Bill
Hate to admit this, but I had Concat and Output in the wrong fields (Attachments Name-1 and Attachments Content-1). All I had to do was reverse them.
Bill
Hi Bill
We might need a bit more info such as the exact error you’re getting. If you’re interested in more formal help, there are a couple of freelancers such as Mark Stokes who has a microjob for exactly this type of activity: https://jobs.collab365.orgmunity/jobs/flow/i-will-help-you-bug-fix-your-microsoft-flow-for-up-to-two-hours/
Regards
Matt
Hi Bill, what’s the trigger that you’re using for your Flow? Also, are you seeing any error messages when you’re running it?
