Hi everyone,
Scenario: I have over 1,000 folders and I would like to create a subfolder within each of them titled 2015.
Example:
TAS10/2015
ABC/2015
XYZ/2015
How would I go about this?
I can provide more information if required. Note: I am using SharePoint 2013.
You can create PS file by modifying below code as per requirement.
This script creates 2015 folder under Manesh folder in list.
After completing your script files – execure on power shell comand promt – one time activity .
$webUrl = “Site URL”
$listName = “Test”
$subFolderName = “Manesh”
$newfolderName = “2015”;
$web = Get-SPWeb $webUrl $list = $web.Lists[$listName]
$subFolder = $list.RootFolder.SubFolders.Item($subFolderName);
$folder = $list.AddItem($subFolder.ServerRelativeUrl, [Microsoft.SharePoint.SPFileSystemObjectType]::Folder, “$newfolderName”)
$folder.Update()
$web.Dispose()
Do you know how to write a powershell script for this?
This can be done by following approaches :
1. using sharepoint server side object model – write console application to create folders
2. Write Power shell script and execute
3. client object model – not sure about this
