how to access CRM with Sharepoint using plugins…….
Using Dll’s, How to connect CRM with SharePoint like CSOM
Yes, after implementing it I can say its not a brainer but will require some additional stuff needs to be done to get/ generate the authentication token.Â
I think that the following article will help you.
https://mobilunity.com/blog/10-reasons-to-hire-microsoft-sharepoint-developer/
I hope this helps. If my post answer your questions, please mark it as helpful/ verified.
Hi Anil,
am not pulling data from both ways. CRM with sharepoint means CRM already integrated with sharepoint.
CRM provided one Sharepoint url so based on that I need to connect this site.(so I need to connect CRM of the SharePoint URL) Using coding to connect that URL. I dont know how to connect url using pulgins(dlls).Â
thanks,
Aruna
Hi Aruna,
Can you please answer these questions:
1. Are you pulling data from CRM to SharePoint ?
2. Are you pulling data from SharePoint to CRM ?
Which one your going ?
Hi Aruna
If you meant some thing like SAP data to be exposed via Sharepoint solutions , you may look at DUET implementation which let’s you achieve it by exposing Sap data as few external lists.
Hi ,
Thank you for sent me the Information of above question. This is the part of CRM with SharePoint Implementation. We are using CRM online site with SharePoint. Now they activated SharePoint integration in the CRM site. So they have a plan to implement web parts and deploy into the SharePoint with CRM site. Actually SharePoint On premise, we will implement Client Object Model for SharePoint Content Implementation so same thing like here also we have to develop Code for Connection of  the CRM with SharePoint site and Develop the certain Custom web parts.
      For example in .Net with CRM, they had below DLL’s for implementing the Code and integrate the .Net application into CRM.Â
using Microsoft.Xrm.Sdk;
using Microsoft.Xrm.Sdk.Client;
using Microsoft.Xrm.Sdk.Query;
Same thing I have to develop Custom Web parts in CRM with SharePoint site. Here I didn’t get any DLLs for connect CRM with SharePoint and Deploy into CRM with SharePoint site. ( Normally we have a option for SharePoint JSP file creation to connect CRM site but I don’t know how to implement this one. I have tried but un succeeded. ) Please share me your information.
If you understood please revert me .
Thank & Best Regards,
Aruna.
