Hi, I was fiddling with the search webparts in 2013. When you use the Pages webpart and select the “picture with 3 lines” template; SharePoint cuts off the text at the end of the line. I’d like my description to be multiline, let’s say 3 lines or so. I tried creating a custom display template, but didn’t find a way to modify this behaviour. Has anyone found a good solution for this?
Found it; simply remove the CSS styles in the display format.
