Hi there guys,
I’m having a problem using Dashboard Designer and i don’t really know hoe to solve is. Here my scenario:
1 – I have a scorecard in dashboard designer and my datasource is a simple sharepoint list
2 – I have “named sets” in my scorecard so evertime a new item is added to the list it will update the scorecard automatically
3 – The only problem is that when I use “named sets” the expand/collapse function of the scorecard doesn’t works (it works only when i use dimensions but using dimensions doesn’t update my scorecard doesn’t update when new items are added to the list).
So I’m stucked with this 2 points:
1 – If i use dimensions the expand/collapse function works but if I add items to the list they are not added to my scorecard automatically
2 – If I use “Named Sets” the scorecard is updated automatically when new items are added to the list but i loose the expand/collapse function.
Do you know any ideia how can i solve this expand/collapse “problem” ?
Thanks in advance
