I would like to add a webpage inside my powerapps like an embedded webpage inside powerapps.
Is that possible to do like that ?
Thanks.
Hi, unfortunately I do not believe there is a control to embed a web page onto a PowerApp form.
I’ve been trying to forward a port but the router page doesn’t display properly. So the problem was either my router or my ISP. I am facing problems accessing specific websites and it takes forever to load even I also contact Linksys router support experts about my query and he said there is no problem with your router and contact your network operator. So do you have any idea about this?
You cannot embed a webpage but you can use the Launch feature to open a webpage. Check the below link for sample.
https://powerusers.microsoft.com/t5/General-Discussion/Hyperlinks-in-Powerapps/td-p/1477
