Experts,
I`m trying to enable Breadcrumbs in SharePoint 2013 based environment.
Found an article, that suggest it should be simple by modifying the values in settle.master
Article: http://blog.sharepointexperience.com/2015/08/sharepoint-2013-breadcrumb/
However, its not working for me
Any suggestions?
We had the same problem so decided to come up with a solution.
Check out for free FlyView for SharePoint. A free Chrome plug-in. Simply add it to your Chrome and go to your sharePoint site, it works. Versions for all the other web browsers are also available.Â
https://chrome.google.com/webstore/detail/flyview-for-sharepoint-an…Â
cheers 🙂
Syed Hassan
