I’m running high sierra & recently installed Microsoft Teams. The first two days it seemed to work fine and all of a sudden it threw up an error 2:0211. I tried to uninstall & reinstall the app but ended up with a negative result. I happen to Google & there was a post with a solution: Go to Go>Go to folder & type in ~/Library/Application Support/Microsoft & delete the Teams folder. This was done & did fix the issue but the error returned after a reboot. Now every time the error occurs I need to repeat the same procedure. I contacted Apple in regards to this & I was asked to contact Microsoft. Is there a permanent fix for this error?TIA
Regards.
Vikram. R
