Hi Guys,
Was trying to install share point 2016 beta 2 preview version at home PC . All works well till i ran PSConfig wizard.
It errors at step 3 and giving a weird error of office.server.search dll . Digging more in logs it seems that it is not
able to start SPTRACEV4. Though I am using Farm account to run the wizard.
SQL server 2014 R2 with SP1 is the database.
Any helps and ideas???
Thanks in advance.
Okay I will try this.
But I m very much eager to solve this problem at least.
OS is window server 2012 R2 and yes I m using SQL 2014 SP1 . Both are on the same server I mean single machine no VM also.
Can you use SharePoint Server 2016 RTM instead?
https://www.microsoft.com/en-us/download/details.aspx?id=51493
There is no SQL 2014 R2, so I’m assuming you’re using SQL 2014 SP1. What operating system are you installing on? Windows Server 2012 R2 is the minimum.
