I need help finishing a Custom SharePoint 2013 Office 365 Web Part / App Part.
Webpart Overview: The “Employee Spotlight” is ideal for a company intranet home landing page. This will help drive user adoption and encourages team members. Employee Spotlight webpart will be powered by a custom list with custom columns for the metadata. (This part is already built)
The current solution is already built in an Office 365 Development site using Napa Development tools and Visual Studio. See attached Web Part screenshot.
Current Solution leverages.
-Napa Development Tools (Office 365)
-Visual Studio
-SPServices
-Font Awesome
-JavaScript
-HTML / CSS
The solution is complete and working but I need help finishing it and making some adjustments, Below are the outstanding items that need to be completed leveraging Napa / Visual Studio.
Requirements:
Review current solution for best practices.
Add the creation of a custom list and fields when the App is deployed on Office 365. This custom list is used to populate the App / Web Parts content.
Web Part custom configurations when you edit web part such as:
The webpart can be configured to filter the display content for a specified amount of days.
The webpart can be configured to filter the display content view to show 1 or multiple items with pagination at the bottom to see additional items. Pagination should be a smooth transition using jQuery to fade and or slide to the next set of items.
