I want to purchase a 3rd party product from a contributor on End User SharePoint, however since his company is located in Russia, and we are in the US, our legal team wants to feel a bit more safe if possible before making the purchase.
Can anyone vouch or validate or confirm the integrity of the following company?
Contributor Dmitry Kozlov
is the leader of the SharePoint Forms Designer Team at SharePoint Forms Designer and
Co-founder of PlumSail. Follow him @spform
Articles:
Thanks!
Sincerely,
Matt
Hi Armon,
I am still a huge fan of Plumsail and SP Forms. They continue to innovate and support their products and I would definitely recommend them after years of experience. I think they are a leader in value when it comes to 3rd party solutions. I do not suspect you will be disappointed if you go with them.
Hey Matt,
We are an Israel located company and we are looking to build solutions for complex forms and work flow management on top O365.
We have a big questions to build the solution on power apps and are concerned about the significant limitations that still exist in this tool.
The Nintex is not an option for us.
For this reason I would like to test your experience with Plum Sail as a product and as a solutions provider as well.
Can you still recommend the product after 3 years’ experience as opposed to other solutions?
Thanks in advance
Armon
Update!
Since posting this question, my company has purchased “Forms Designer” from PlumSail, largely because of the very positive feedback we received from other customer referrals that I was given the option to contact.
Since becoming a customer, I have been very pleased with the product and the support for the product. This tool is a great InfoPath Alternative and I would highly recommend it to others looking for form solutions. I won’t take all of your time and go into every feature and value I love about this product, but I will name a couple of my favorites.
- When you talk about products that are fully integrated, versus being bolted onto SharePoint, you can really feel much more confident about the solutions. This product writes .aspx forms, just like the stable OOTB forms that SharePoint Likes.
- Related to #1 in a way, these forms work fine with other 3rd party “special columns” that you may have purchased, as well as managed meta-data columns.
- The sky is the limit on what you can do with the forms( The sky here is your knowledge of CSS and JavaScript), and it could not be easier to integrate.
Again, I highly recommend this product as a great SharePoint Forms solution. You can feel confident in purchasing this product, as PlumSail appears to be a solid and upstanding company.
-Matt Schuessler
@mattschues
Hey Matt
The Nintex option is not compatible for us.
Thanks in advance
Armon
