Hi all
A simple question but i was not able to change the text box and it keeps cutting off words i have copied and pasted- as can be seen below
I have check properties but not having success in editing the Community Discussion List
This has not to do anything with the column properties, rather you need to check out your css in the view page. Some css is meddling with the width of the div that holds the body text. Â
