I have a List called Test1 and below are the controls (only for testing purposes).
Below is my Designer 2013 workflow associated with the list above:
The workflow does the following:
- When a user submits a new item, the workflow Updates the DueDate to equal to a Calculated column called CalcDueDate. The calculated column is formulated to display the date asCreated + 14days shown below:
- It then sets a variable
- I am using a Parallel Block because I have multiple scenarios that will move the workflow to the next step depending on what the user has selected. This parallel block will stop if loopVar returns True (Yes) in Parallel Block Advanced Settings.
- Next, in Email Loop Step, as long as loopVar = No, then the loop will pause for 1 minute and email Created By. This will continuously loop and email every minute.
- On the Step Change Color To Red, a user can break out of the Parallel Block if Colors = Red. This immediately stops the looping with continuous email every minute as expected.
The Step Break Loop is my focus. The desired effect is that when a user changes the DueDate to something other than what is already set by the Update activity, then it will exit the Parallel Block and move to the next Step.
In other words, if the DueDate has been changed then break the Loop and go to the next Step.
The issue:
When the DueDate has been changed, the workflow continuous the Pause activity and Emails the Created By one more time before finally breaking out of the Loop.
The desired:
When the DueDate has been changed then immediately stop the Loop and move to the next step.
However, I can’t come up with the logic that can do this and one that would actually work for that matter. I have been testing numerous possibilities but the same issue persists.
Any assistance would be helpful.
