I have synced the Document library from a site to my PC. The site was deleted. I am not able to delete the folder from my PC
If you did use OneDrive, there is a Stop sync option under Account tab of OneDrive Settings. You can manually delete the folder in File Explorer once you no longer see the checkmark/cloud icons.Â
Did you use onedrive client to sync the documents?
