Hello @all!
Basically, I want to create a personal salutation based on columns in my sharepoint contact list. The logic is, that if the salutation code is female (“w”), I want it to start with “Dear Mrs.”, if it’s male (“m”) with “Dear Mr.” and if it’s an Organization with “Dear Sir or Madam”. Then, I want to concatenate this part with the job title and the name.
I created a calculated column wit the following formula: (all in German, but same logic)
=WENN([Begrüßungscode]=w; “Sehr geehrte”&” “&[Anrede]&” “[Titel]&” “&”[Name]”,”) OR ([Begrüßungscode]=m; “Sehr geehrter”&” “&[Anrede]&” “[Titel]&” “&”[Name]”,”) OR ([Begrüßungscode]=Organisation; “Sehr geehrte Damen und Herren,”, “not OK”)
Could you help me to find out, whats wrong with this syntax?
I’m happy for any clue to the right direction 😀
Thanks!
Hi, Luisa.
The typical OR operator is added before the comparison for calculated column functions.
IF(OR(Something is True, Something else is True), Value if True, IF(Something is True, Value if True, Value if False))
You can check more samples in this Office article.
