I have designed an info path form and published successfully to the web.
Then I go testing, the info path form is in used (it was automatically added to default new, edit and display form).
But when I open SharePoint designer, I found that info path form is not set to default, so I couldn’t get content type of that info path form in C# (or JSOM), that means it always return the default content type of SharePoint list. See the picture for more infomation:
