Hi all
How are you? I have a problem with the Searchbox webpart, which the results page tend to give results including Topic and Lists. However i would like the Search box to show ONLY results from the First Discussion Post from the posts on the Discussion list (i do not need hits from replies too)- is there anyway to do that?
Please check microsoft reference doc. it can be helpful for your query.
link:
- https://docs.microsoft.com/en-us/sharepoint/search-box-web-part
- https://docs.microsoft.com/en-us/sharepoint/search/configure-properties-of-the-search-box-web-part
- https://docs.microsoft.com/en-us/sharepoint/search/how-to-configure-the-search-results-web-part-to-use-a-new-result-source
I don’t see a way out to customize the search box. The replies are stored in a separate internal list. What you can try is disabling this list to index its content from list settings. But this would remove replies from search as a whole(results too).
