Thinking to put some light on the Copy and paste feature of microsoft that is oftenly used while writing a blog or an article.Many times people in extreme excitement to write blogs are copying and cheating others data which results in creativity violation.
Some method should be in place to remove such acts and blogs for verification once submitted should be checked and then published.
What you say?
Well vlad thanks for the reply and i agree with you that writing on the same topics is not bad but for the sake of increasing number of hits and other website traffic growth makes the knowldge way bad i guess
Hello Ayush, I perfectly agree with you that Blog that are copy/paste of Technet, are complete waste of time., because you already went there!Â
However, as long as they add something extra… it’s worth it!Â
As for the copying of others, like with anything, Â plagiarism is bad! Â However, it’s not wrong for many persons to write on the same topic, with different views. Â Or , get inspired by a blog post and add something to it!
