Can any one explain or give me any reference how to work with the Managed Metadata column type in a SharePoint List?
Thanks in advanced.
Are you looking to use managed metadata as part of your list? If yes check the below link.
https://support.office.com/en-us/article/create-a-managed-metadata-column-8fad9e35-a618-4400-b3c7-46f02785d27f
Or are you looking to access metadata columns in code level?
Managed metadata gives you very wide range of flexibility.
It is very useful on every level of Sharepoint.
You need to plan you r data availability forst and than start creation of metadata slots.
I can write alot, but it is also a lot of written by other people.
Please read this article:
https://sharepointmaven.com/document-management-in-sharepoint-without-folders-introduction-to-metadata/
What exactly do you have for questions? Here are some links about managed metadata.
https://docs.microsoft.com/en-us/sharepoint/managed-metadata
https://en.share-gate.com/blog/sharepoint-2013-whats-new-with-managed-metadata
Hi, Abdullah.
The key advantage of Managed Metadata column is it can be reused across site collections.Â
You’ll need to add a Term Set using Term Store management in SharePoint Admin center or Site Settings.
You can then add a Site Column or List column and use the Managed Term set you’ve created.Â
