Hi everybody,
I have got a VM which has been partitioned to several drives. IT people have installed Sql Server 2012 on D: drive and asked me to install SharePoint on same (d:) drive.
Do I Listen to them and install SP on D: drive or not? MS SQL already installed on D: so is it ok to install SP on C:?
thanks
Hi Kourosh,
If you tried it, SharePoint will tell you that it needs to be installed on Windows drive.
Only SQL, you can change the path of the DBs to be on another drive not the Windows.
