Hi ,
As I was read about the new News about integration of SharePoint 2013 and Moodle (http://www.moodlenews.com/2016/interested-in-integrating-sharepoint-with-moodle/),Dose any one know the step to configure Moodle with SharePoint 2013 ..?
I hope to find response ASAP
Thanks in advance …
Hi Yusif,
Can you explain a bit more what you need to do? I see the link you posted, are you having trouble buying and configuring that? Or are you look for another solution?
Great Yusif. You could build something customized out using SP-Addins or SPFx. Moodle has an extensive API https://docs.moodle.org/dev/Core_APIs
Hi Beau ; I want to integrate Moodle learning service with SharePoint 2013 ,So that It will be under SharePoint platform
