Hi All,
is there any direct way to migrate SharePoint 2007 to SharePoint 2013?
- http://www.topsharepoint.com/content-migration-tools-for-sharepoint
- none of tools in above link can migrate directly from sp 2007 to sp 2013?
- except Sharegate?
Please share your migration experience
Regards,
Swati
There are several migration tools to use. But DocKIT for SharePoint from Vyapin can be used and tailored to your specific migration needs if you can contact Vyapin. It scores well on various parameters like cost, satisfaction and bulk migration capability in crunch time. You can also try a trial version to see if your specific migration needs are fulfilled. You can always provide a feedback.
hi swati
use sharegate tool its very simple tool and you can do migration very fast. if you need help pin me or call me 0065 93672287 or mail me santhiswaroop.naik@gmail.com.
i can help you how to do in sharegate. i had done migration from sp2007 to office 365 using sharegate and ut was awesome.
Hi Swati,
            Yeah many migration tools is there .If you don’t want migration tools means you can choose DB mount option  migrate moss 2007 to 2010 and then sp2010 to sp2013 .
Regards,
Tamil.
