Is there a way we can display List Item ID in Info Path Display form and Edit form?
Jonas,
Thanks for the simple solution. It worked for me.
If you need a List Item Id from a different list, add a secondary data connection  in the form to the list from which you need the ID.  if this isn’t what you are trying to do, please provide more details.
Drag the ID field from the Fields list on to the form.
