A customer of mine can’t pick “Link to a document” when trying to add a new list content type. It’s there as a site content type, but just can’t be picked – any ideas ?
Update: I wrote this post : How to use a ‘Link to a document’ in place of a real document in SharePoint‘.
maybe a WFE only has parts of it. .. that would be a symptom of a grander problem
I will double check though, because its the only reasonable explanation, unless they deleted the content type.
thanks for helping.
Because they aren’t doing it on the right kind of list
Hi Stacy
I can’t repro it. But to get backgruond, they are following steps on here : http://www.collaboris.com/blogs/collaboris-blog/policy-management/2013/04/03/use-a-link-to-a-document-in-place-of-an-real-document-in-sharepoint but when they get to bit where they are adding to the list, its now showing up.
Anyway, don’t worry about it. I will continue to dig around.
Mark
