Deprecated: strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 7025
Deprecated: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 2162
Deprecated: Hook imagify_allow_picture_tags_for_webp is deprecated since version 2.2! Use imagify_allow_picture_tags_for_nextgen instead. in /www/collab365_296/public/wp-includes/functions.php on line 5758
List threshold issue for Group By - Collab365
Deprecated: strstr(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 1145
Deprecated: stripos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 1152
Deprecated: stripos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 1155
Deprecated: strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 1162
Deprecated: strpos(): Passing null to parameter #1 ($haystack) of type string is deprecated in /www/collab365_296/public/wp-includes/functions.php on line 1165
Warning: Undefined array key "url" in /www/collab365_296/public/wp-content/plugins/thrive-visual-editor/thrive-dashboard/inc/smart-site/classes/class-tvd-smart-shortcodes.php on line 85
Collab365
__CONFIG_colors_palette__{"active_palette":0,"config":{"colors":{"1016c":{"name":"Main Accent","parent":-1},"f88c6":{"name":"Main Accent Light","parent":"1016c","lock":{"saturation":1,"lightness":1}}},"gradients":[]},"palettes":[{"name":"Default","value":{"colors":{"1016c":{"val":"var(--tcb-skin-color-0)"},"f88c6":{"val":"rgb(251, 234, 234)","hsl_parent_dependency":{"h":359,"l":0.95,"s":0.66}}},"gradients":[]},"original":{"colors":{"1016c":{"val":"rgb(55, 179, 233)","hsl":{"h":198,"s":0.8,"l":0.56,"a":1}},"f88c6":{"val":"rgb(235, 246, 251)","hsl_parent_dependency":{"h":198,"s":0.66,"l":0.95,"a":1}}},"gradients":[]}}]}__CONFIG_colors_palette__
  • Blog
  • Join the Collab365 Academy
  • About us
  • Useful Links
World-class Microsoft 365 training delivered to your Academy account, on auto-pilot!
ANNOUNCEMENT: this Forums service is now discontinued. keep a  lookout, because we're  in the process of launching an exciting new community offering .... #365ers!
Share 0
Tweet 0
Pin 0
5.60K viewsOctober 23, 2013Security and Governance
Dipti Chhatrapati0 October 23, 2013 0 Comments
Can anyone please help me out for following issue ?
http://social.msdn.microsoft.com/Forums/sharepoint/en-US/37c88bca-dde9-4eb5-882f-5baad7e1bc3a/group-by-list-view-throwing-an-error-after-changing-list-threshold-value?forum=sharepointdevelopmentprevious
Thanks for your time to look on..
(Visited 128 times, 1 visits today)
  • Active
  • Voted
  • Newest
  • Oldest
1 2 Next »
Aniket Patel0 Posted October 28, 2013 0 Comments
Try to disable throttling for that list and see if it works.
here is the link of how to do it. :
http://spservices.codeplex.com/discussions/280642
Also try to disable the feature called : “ViewFormPagesLockDown” and see if that works. This feature has been issue with permissions.”
Dipti Chhatrapati0 Posted October 23, 2013 0 Comments
yes thats the only issue I too think so, but Microsoft has not provided any group by limitation like that…so I belive there must be solution…and I am looking for that …Plus I cant remove persmissions..
Do you have any reference link that specify that with 5000 list items level permissions cant work with group by view ?
Aldo Mar0 Posted October 23, 2013 0 Comments
Hello Dipti,
Item level permissions seem to be the source of your problem then. I suppose that SharePoint has to scan the entire list in order to determine permissions, before even grouping by the indexed column, thus hitting the threshold.
Unfortunately, you’ll have to either remove the item level permissions or increase the list view threshold for your view to work.
Also , I checked the filtering approach you have specified, but still I am facing the same error. I believe its issue with item level permission load, however there is no any reference link by MS saying the limitation for Sharepoint list group by view.
Can you please help me out on this further ?
Thanks a lot Aldo Mar to look on this issue !!
Well , there is an item level permissions too , If I remove item level permission then group by works…that is what I found in new created list using template where item level permission was not there and hence it was grouping the item even it was more than 5000.
above issue we observer through sql profiler tool while querying list with item level permission and without permission , with item level permission the load over list was high and hence somewhere its got wrong and groupby didnt worked.
I will check out the filtering approach you have pointed out and let you know .
1 2 Next »
Login
Summit Bundle
Get 200+ hours of Microsoft 365 Training for 27$!
Master Office 365, Power Platform & SharePoint & Teams With 200+ Hours Of Training Videos and 108 Ebooks in the Collab365 Academy. This offer is insane and is only available for a limited period.
Get 200+ hours training for 27$
popular links
  • Ultimate Guide to Microsoft Forms
  • What's in a Microsoft 365 subscription?
  • Best SharePoint Intranet Templates
  • Microsoft Teams Administrator Course
  • Microsoft Teams Governance Workshop
collab365 network
  • Collab365 Daily Digest
  • Collab365 Blog
  • Collab365 Events
  • Collab365 Directory
  • Collab365 Certifications
about us
__CONFIG_colors_palette__{"active_palette":0,"config":{"colors":{"f3080":{"name":"Main Accent","parent":-1},"f2bba":{"name":"Main Light 10","parent":"f3080"},"trewq":{"name":"Main Light 30","parent":"f3080"},"poiuy":{"name":"Main Light 80","parent":"f3080"},"f83d7":{"name":"Main Light 80","parent":"f3080"},"frty6":{"name":"Main Light 45","parent":"f3080"},"flktr":{"name":"Main Light 80","parent":"f3080"}},"gradients":[]},"palettes":[{"name":"Default","value":{"colors":{"f3080":{"val":"rgba(23, 23, 22, 0.7)"},"f2bba":{"val":"rgba(23, 23, 22, 0.5)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}},"trewq":{"val":"rgba(23, 23, 22, 0.7)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}},"poiuy":{"val":"rgba(23, 23, 22, 0.35)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}},"f83d7":{"val":"rgba(23, 23, 22, 0.4)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}},"frty6":{"val":"rgba(23, 23, 22, 0.2)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}},"flktr":{"val":"rgba(23, 23, 22, 0.8)","hsl_parent_dependency":{"h":60,"l":0.09,"s":0.02}}},"gradients":[]},"original":{"colors":{"f3080":{"val":"rgb(23, 23, 22)","hsl":{"h":60,"s":0.02,"l":0.09}},"f2bba":{"val":"rgba(23, 23, 22, 0.5)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.5}},"trewq":{"val":"rgba(23, 23, 22, 0.7)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.7}},"poiuy":{"val":"rgba(23, 23, 22, 0.35)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.35}},"f83d7":{"val":"rgba(23, 23, 22, 0.4)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.4}},"frty6":{"val":"rgba(23, 23, 22, 0.2)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.2}},"flktr":{"val":"rgba(23, 23, 22, 0.8)","hsl_parent_dependency":{"h":60,"s":0.02,"l":0.09,"a":0.8}}},"gradients":[]}}]}__CONFIG_colors_palette__
  • About Collab365
  • hello@collab365.com
Privacy policy
Terms and Conditions
cookie policy
Badhan Ct, Castle St, Hadley, Telford, Shropshire, TF1 5QX, UK
Copyright 2026 Collab365, all rights reserved.
