Hi
I am using SharePoint (2013) managed metadata navigation , but have found a bug. when setting the “Navigation Node Type” it says if you don`t provide a URL for the simple link or header , the navigation node will be text only. For my setup when i do not provide an URL it is not text only but a clickable link , which normally goes to a invalid page.Seems to be generating the page ? Could anyone help me investigate this or suggest a work around. Some navigation menus need only to be text headers but i cannot get this to work with the managed metadata navigation? Many thanks Andrew
Here is an update to clarify.
What i mean is that some navigation nodes need only to be text headers. So if i leave the navigation node field “Simple link or Header” empty these nodes should only be text headers but for some reason they are clickable and a URL generated. No coding only out of the box.
Very weird. Yea sounds like a bug. I’ve tested in my SPO environment, and it appears to be working correctly for me.
Hi
Something i didn’t know was that there is some embedded JavaScript that was developed by a third party (before i joined the company). This is causing the navigation not to function correctly. Thanks for confirming that it worked from your testing as it helped us track down the final issue.
Best regards
Andrew
I’m not sure I’m completely following. You aren’t specifying a SimpleLink and you are expecting this to create a Term in navigation, but go to a broken page?
Are you doing this via code and if so, can you Share? Generally speaking the terms will inherit from parent term sets for the navigation by default.
