There is a very strong possibility that I will be tasked with an awesome project; Migrating SharePoint 2010 Foundation to SharePoint 2013 (Foundation, Standard, Enterprise, who knows). Here’s a little of what the potential client will expects help with; high level write up sent by the client (a few points)
- Analyze existing site collection structure and make design recommendations to improve usability
- Make recommendations for design of architecture/server farm, estimated growth and
security for VMware. - Make recommendations for redundancy / backup to cloud
- Make recommendations for an Enterprise SQL Server DB that would store the SharePoint
content - Outline an approach for migrating to the new platform including recommended tools to assist in this process
There are other items as well but for now I only want to stick with migration. I know there are lots of questions I need to ask the client; What are they??? I would like some feedback from the community on their experiences and resources used to be successful on this venture. I have done migrations in the past wss to 2007 to 2010 internally but this is a different ball game as someone else outside of our company is looking for expertise.
Regarding SharePoint Migration we should ensure some things. We can ask some questions to our SharePoint Migration Consultants are as follows:-
- How stable your SharePoint(any version)?
- What is Min Role?
- Do architectural changes include or not?
- Whats migrated?
- How can we fix bugs?
Hey Jason,
Here is some stuff that I would ask the client:
- Do you have any custom solutions? Do we need to recode it, do you want to keep same code, etc.Â
- Do you want High Availability / Disaster Recovery in your new environment.Â
- Do you want to migrate content as is, or do you want to re-organize content.Â
For analyzing current site collection structure, make sure you check if security is clean or not as well as DB Size. Â Do they have 1 Site Collection with 1000 sub sites that makes only 1 content DB of 1TB, or they split it up well.Â
Server Architecture will depend of # of users as well as HA/DR Requirements. Â SharePoint can (in theory) easily add servers, so shouldn’t be worried about growth.Â
Check this out for DR in the cloud >Â http://azure.microsoft.com/en-us/documentation/infographics/sharepoint-sqlserver-alwayson/Â
Enterprise SQL Server Recommandations > Read this Whitepaper done by me  > http://1drv.ms/1o4JubZ
Either using tools or not will depend if they want to  change content structure . IF they don’t wanna change content, I suggest using a DB Attach. If they want to change and reorganize content, I Suggest using a tool such as ShareGate. (see a list of tools here: http://sharepoint-community.net/page/sp-migration-tools) .
If you are doing DB Attach, here is what I Suggest.
- Migrate 2010 > 2013 , but keep in compatibility mode. Â This will bring you some new 2013 features, and will let you upgrade your code meanwhile if you got any.
- For Every Site Collection, simulate the upgrade to 2013 mode. Â If it works well for you, do the upgrade!
Lastly, check out this session from SPC14:Â The nuts and bolts of upgrading to SharePoint 2013″Â Â http://channel9.msdn.com/Events/SharePoint-Conference/2014/SPC410Â
Hope I helped you a bit and I am sure other members of the community got other stuff to add!
