I am trying to modify the display of a library column header to show a different name than the default name. The column I am trying to change is the “LinkFilename” column which is the column that links to the actual document. The default display name for this column is “Name” and I want to change it to something more user-friendly like “Form Name”.
For this library named “Administration Policies” (actually I need to change this on all my policy libraries), I created a custom view called “PolicyView” which I show as a screenshot from SPD below.
I open the PolicyView in “Advanced Mode” and modify the <XmlDefinition> as shown below:
<XmlDefinition>
<View Name=”{C1E366E6-CF67-410B-8577-23E094E43FC3}” DefaultView=”TRUE” Type=”HTML” DisplayName=”PolicyView” Url=”/policies/Administration/Forms/PolicyView.aspx” Level=”1″ BaseViewID=”1″ ContentTypeID=”0x” ImageUrl=”/_layouts/15/images/dlicon.png?rev=23″ ><Query><OrderBy><FieldRef Name=”LinkFilename” Ascending=”False” DisplayName=”Form Name”/></OrderBy></Query><ViewFields><FieldRef Name=”DocIcon”/><FieldRef Name=”Title”/><FieldRef Name=”LinkFilename” DisplayName=”Form Name”/><FieldRef Name=”RevisionDate”/></ViewFields><RowLimit Paged=”TRUE”>101</RowLimit><JSLink>clienttemplates.js</JSLink><XslLink Default=”TRUE”>main.xsl</XslLink><Toolbar Type=”Standard”/></View></XmlDefinition>
</WebPartPages:XsltListViewWebPart>
Am I working in the right direction? When I save the PolicyView.aspx file and refresh my browser I do not see any of the changes.
Alex
JSLink is harder, you have to remake the entire header row for the view. The bonus is that if you have multiple views, you can change the wording on a per view basis.
To start with templates, take a look at the raw template project SPCSR: https://github.com/SPCSR/DisplayTemplates
I am still troubled by the fact that I have to manually to into these file one-by-one. Is there a better way to solve this issue? How would it be done using JSLink?
I just made a change at it appears to work. I feel like a real “twit” if this is a good fix and I didn’t see it before.
I clicked on the “Customization” under the “Administration Policy” list as shown below to “edit list columns”
Then I renamed the “Name” column to “Form Name” and saved the file.
This seemed to have done the trick … as shown in the following screenshot
