First of all my apologies if this has already been asked and answered elsewhere, i have been trawling.
I have the task of creating a workflow that is triggered on a specific list upon a items field (ReferenceNumber) being populated. If so, then a lookup runs to check whether a doc set (under same reference number) within another library already exists. If so then move the file into it. If not, then create the doc set and then move the file into it.
Copying a document into another library location is fine, and even creating the doc set within that library is fine, but i’m falling short when I try and move the file into the document set. It gives me the option for the list, but unfortunately there is no further specifics.
It seems pretty simple within older version of SP using the ‘Copy item Extended’ option however this facility does not seem to be present with SPD2013 and i am currently having little luck in enabling it.
Can anyone lend a hand? Your time and efforts are truly appreciated.
Thanks.
For those interested, I found that the only real option is to use a 2010 workflow within SPD 2013 as that the only way of accessing the ‘Copy Item Extended’ option which to my amazement is not present within 2013 workflows at all. Further details can be found under the following link.
http://social.technet.microsoft.com/Forums/en-US/c19ca2ea-6760-466d…
