Hey everyone,
Something happened with column % complete in one of my project opened via PWA. All tasks showing 0 % complete. When I open the same project by Project Professional everything looks fine.
Any suggestions how to troubleshut this issue ?
You check (link https://servername/PWA/MyJobs.aspx ) failed jobs.
Or
B1: Create new project | Insert task , input % completed | Publish | Check in Project
=> check % completed ( MS Project web app and Project Pro ) the same
B2: You clear cache in project professional 2013 (File – Options – Save – Clean up cache … -Remove From cache
Good luck
