Y’all,
Since I won it on the community, I thought I might ask some other developers.  1) Are there apps like snagit to capture screen shots (I found a way through a key combination to take a snapshot–but it’s the whole screen). 2) How do you do JavaScript Debugging from IE?  It seems there are two versions of IE running one from the start panel and one from the desktop.  (The one from the desktop allows access to f12–so I might be able to access the scripts. When I opened an html file it accessed the one from the Start Panel–which doesn’t respond to function keys.)
Also noticed a problem on skydrive creating folders.
Just slightly Surface-Challenged.
(Visited 23 times, 1 visits today)
