I work wiht MSSP2010 Foundation.
I have a workflow implemented in a develop local machine. The application sends several emails to different users involved in the workflow. My application and the workflow run ok.
Then I create a package and I update the application in a pre-production server. In this pre-production server the WF work ok, but 1 of the 4 possibles emails never is sent to the final user. The other 3 possible emails run well.
I think that, the problem with the email that never run, must be related with the sharepoint configuration on the pre-production server.
What configuration could I check in order to detecting the problem?
Thank you in advanced for any idea.
Regards,
MarÃa
Firstly:
Have you configured the outgoing email setting correctly in SharePoint in your pre-producation environment:
For SharePoint you need to check the area in central admin
CentralAdmin– SystemSettings—- Outgoing email setting
Secondly:
What is your workflow type i.e. SharePoint designer workflow or workflow developed with VS?
Thirdly:
Your issue seems to be strange because 3 out of 4 emails are send correctly … Looks like an issue in your workflow action for email.
