Hello All,
I’m trying to insert and delete with the same function ,which I called on img onclick.
It is working fine in Insert case but not running in delete case.
Need your assistance.
Here is the codeĀ snippet
function checkClick(elem)
var ctx = new SP.ClientContext.get_current();
var list = ctx.get_web().get_lists().getByTitle(“UserAppStationTest”);
ctx.load(list);
alert(‘hello list is loaded’);
var listItemCreationInfo = new SP.ListItemCreationInformation();
var insertItem = list.addItem(listItemCreationInfo);
var i=’/sites/OptiBoltUAT/_catalogs/masterpage/OptiBolt/images/wallpingray.png’;
var ImageBtnID = elem.id;
alert(ImageBtnID);
var userName=”abc@gmail.com”;
var msglist = document.getElementById(ImageBtnID);
var getattr=msglist.getAttribute(“src”);
if(i===getattr){
msglist.setAttribute(“src”,’/sites/OptiBoltUAT/_catalogs/masterpage/OptiBolt/images/wallpin.png’);
var camlQuery = new SP.CamlQuery();
camlQuery.set_viewXml(‘<View><Query><Where><Eq><FieldRef Name=\’ImageID\’ /><Value Type=\’Text\’>’+ImageBtnID+'</Value></Eq></Where></Query></View>’);
var collListItem = list.getItems(camlQuery);
collListItem.deleteObject();
list.update();
ctx.load(list);
ctx.executeQueryAsync(success, error);
function success() {
alert(‘success’);
alert(‘Item Deleted Successfully’)
function error(sender, args) {
alert(‘Failed to insert Error:’ + args.get_message());
else
msglist.setAttribute(“src”,’/sites/OptiBoltUAT/_catalogs/masterpage/OptiBolt/images/wallpingray.png’);
insertItem.set_item(“ImageID”, ImageBtnID);
insertItem.set_item(“UserMailID”, userName);
insertItem.update();
alert(‘success’);
alert(‘Item Inserted Successfully’)
Any help will be Appriciated!
Thanks!
