Hello All .. i was created Document with workflow: but i I confronted The file cannot be opened because there are problems with the contents any help please ?????
thanks Nico for your reply .. so i want to generate word document using workflow i was follow a tutorial and all works fine but when i want to open the word document i get this error :Â
The file test.docx cannot be opened because there are problems with the contents.
Hi Aymen,
Please elaborate on the workflow, what you did and what exact errors you are getting in order for us to help you.
