I have a procedure in which the number of variables I need may vary. I thought PowerShell had this functionality.
Just want to share.
clear the screen
declare 2 variable areas and populate with numbers 1 to 1000
Then replace numbers in the Second Array.
Note: First Array variable is 0:  $b[$_ – 1]
So I have to substract 1
cls
$a=@(1..1000)
$b=@(1..1000)
$a | %{ $b[$_-1]=”var“+$_}
$b
Output:
var1
var2
var998
var1000
If you have any examples where you need sequenced variables chime in and share too.
(Visited 24 times, 1 visits today)
