I have two required field in a document library. I want to use some conditional formatting for them. For example, when I upload a new document, I want the first column to show with several choices. Depending on the choice the user makes, I want the second required column to come up where they can select a secondary option. Is this doable? Right now both required columns come up when the upload file is clicked.
It isn’t really a content type, it’s more that I need two pieces of metadata entered when they upload a new file.
I thought about that, but InfoPath does not support customizing a document library list.
I believe you would either need to use InfoPath or custom Javascript to accomplish this.
