Hi all,
How to create customize web part zone in SharePoint 2013..
Tamil.
Try this URL:Â http://ngpixel.com/post/104502137318/sharepoint-2010-tableless-webparts-guideÂ
Hi Joseph,
thanks for replay,
but URL not open [it’s showing “The URL you requested could not be found.“].
Hi Tamil,
If you really want to control the rendering of the webpartzone, you can always use a control adapter.
Here is a good exemple on how to render webpartzone with divs instead of tables: Â http://ngpixel.com/2011/05/30/sharepoint-2010-tableless-webparts-guide/
Joseph
