Hello.
Thanks in advance,
Theresa
Thanks for sharing your results. I am having the same problem and have tried all the suggestions thusfar. I’m in Office365. Very frustrating.
Thomas,
I found that the library permissions are respected if library settings are set to display it in the the site’s QuickLaunch. Of course you wouldn’t want thousands of QL links; that would make for a very long page.Â
In your scenario, would it make sense to break into subsites based on customer?Â
Hey, J. Schmit.
Funny that you say that Sharegate helped in the test. When we migrated site lists and libraries with Sharegate, it didn’t retain permissions or custom columns. I ended up have to redo some of the sites with ControlPoint. Problem is that ControlPoint only copies one list at a time. Zzzz.Â
Hi, Karim.
Yes, tried again and no consistent results. See my recent update / post.
Hi, Kameron.
In my scenario, no. One farm, one server.Â
