Hi Guys!
I am looking for an way to disable ‘Opening Library With Explorer’ through permissions management in SharePoint 2013. I am using filtering view in web browser, but in explorer all files are shown that is not acceptable for me.
You should be able to go to Central Administration. Go to Manage Web Applications, select your web applications.
Click “user permissions”, find “Use Remote Interfaces” permissions and un-check it. — This doesn’t always respect SharePoint Permissions, so you may need to adjust them as well. You may also see some issues with access to CSOM as well, depending on how customized your environment is.
