Hi, have you tried: psconfig -cmd upgrade -inplace b2b -force?
Re-run the update? Apply March CU? I’m not sure what else to try. Is one of the pictures what you get if you try to re-run the update?
Did you run PSConfig before Step 2 or did it say a reboot was required?
