Hello friends,
I’m setting up a project management site, and am running into many roadblocks. I’m pretty new with SharePoint, so am hoping some of you experts could look over how I’m going about this, and suggest changes or improvements.
Environment – On-premises SharePoint 2013 SP1 Enterprise.
Requirements –
- Setup Rental Development project management parent site that displays task and calendar rollups of project child sites.
- Approx 25 child sites, each child site will represent one active project.
- Each child site displays a calendar and task list. The calendar and task lists rollup to the parent site.
- Each child site has isolated security. Most child site users will not have access other child sites, or parent site.
- All child calendars display tasks from task list, and also other non-project related events. Parent site calendar is a rollup of all child site tasks and events.
- Would like
What I’ve done –
- Created parent project subsite off of main production sharepoint site. Disabled security trickle down. Created child subsites off of parent project subsite, disabled security trickle down.
- Installed 3rd party Amrein Engineering web part that is able to roll up tasks from subsites.
Issues we’re having –
- Task calendar and ‘normal’ calendar apps do not seem to integrate. There doesn’t seem to be a way to display both tasks and other types of events in the same calendar.
- Amrein task list rollup only displays tasks in a list view, doesn’t have a calendar view. Not able to find a product that can. Would prefer to be able to rollup child project sites without having to use a 3rd party app.
- Unable to rollup child project calendars because child projects are in subsites.
I could meet the reqs if we weren’t forced to use subsites for the child project sites. Is there any way to provide the silo’d security we need without having to use subsites?
How would you build out a thing like this?
Thanks in advance to anyone who can comment,
Stephen Barash
Well, figured out and fixed all three of my issues without having to use 3rd party components.Â
I’d write and describe how I overcame these obstacles, but these forums don’t seem to be very lively, so I doubt anyone would notice.
Still, if anyone has similar issues, let me know. I’d love to help.
Stephen
You might find Dux Raymond Sy’s sessions useful. It’s playing on SP24 Rewound. https://www.sp24conf.com/2014-1/Conf/SP24S113/ConfPages/SessionRoom.aspxÂ
Here’s his overview :Â
“In today’s project-centric work environment, the ability to coordinate multiple projects with distributed teams—and making high-level strategic decisions based upon consolidated project progress, risk and resource usage information—is critical. When it comes to project management, every individual, team, and organization has unique needs. Microsoft’s vision for project management is to enable individuals and teams to choose the tool that is the best fit for their specific project while still delivering the visibility that their organization needs to ensure focus on the right priorities. This session will help you understand how all the solutions across Office 365, SharePoint, and Project fit together so you can chart a realistic approach to project management for your organization that will deliver immediate value with an eye to the future.”
