SharePoint alerts work when we create it but after that not getting email. when I delete any document email generate but, when add new document or change the document not getting any email.
It was working fine but suddenly getting this issue.
If the issue still persist, you may also try LepideAuditor suite i.e., (http://www.lepide.com/lepideauditor/sharepoint.html) that helps to get instant alerts for every critical changes into real time through customized email notification.
Follow this article to solve your issue;
http://sharepointalert.info/troubleshooting-sharepoint-alerts/
Revise the alert settings, check your list settings and user permissions, search support.microsoft.com and blogs.technet.com for relevant articles. Consider restarting the timer service.
If that fails, you might need to open a support case with Microsoft Product Support Services.
Hello Akshay,
Thanks for your reply
it was working perfectly but suddenly its start to behave abnormal. i have deleted all alerts and create it again. when i created an alert email is generated but after when i add new document or change existing document alert not work.
but when i delete any document its work. i have no idea why this happening. any solutions…???
go to the ribbon menu find alerts and select Mange alerts to check if your alerts are working as you had set them
