Hi all
I’m trying to perform CRUD operations on the Oracle database ( I’m using a web service) and hence am looking at BDC.
I already have few lists (not external lists!) available on my SharePoint site and workflows are linked to them. As far as I have read, I find BDC links to external lists on which workflows do not work.
All I need to do, is to perform CRUD operations (based on the workflow statuses) on Oracle tables. Will BDC help me? Is there any other way out, other than using a DAL ( I tried the DAL, there is an unacceptable amount of delay in communication between Oracle and SharePoint)?
Thanks for that.
You have mentioned that it could not be done through SPD BCS and have also mentioned that using web service in SPD BCS we could achieve it.
Does that mean that using web services I would need to create a custom BCS and then link it to SPD?
I don’t think it is possible through SharePoint designer BCS. May be you should try creating a web service for having CRUD operations on your Oracle DB and configure the web service in you SharePoint designer BCS. Another alternate solution would be to create a custom BCS from VS 2010.
